Hi all,
Have a CFX question.
I added a Matte to my Fill clip on the desktop. Then I dropped the clip with a matte into my timeline. Then changed it into a CFX composite. Now I need to change the Matte source. I know I can drag a new Source Matte Clip into the CFX Schematic, which works fine. I can then unlink the old Matte and link the new Source Matte Clip. However, once I have unlinked the old Matte clip, I cannot delete it. I believe because I added the original Matte clip as a Matte onto the Fill Clip within the desktop thus creating a Matte Container. I can see the "old" Matte Clip in the "Timing" layers.
How the heck can I swap the original Matte Clip? Or how can I delete it once I have added a new Matte Clip? I would prefer not to "Remove CFX and Recover Stack". Unless there is an easy way to "Unstack" remove the clip and then "Restack" the clips. If I do run "Remove CFX and Recover Stack", I can see the Matte Clip I want to remove.
TIA.
Matt
Solved by mncrnich. Go to Solution.
Okay, I am a moron. Turns out the simplest solution works. All you need to do is literally drop the new clip from the Bin onto the old CFX node. Der.
I guess in an effort to make SMAC more friendly and MAC like, this works. I am so used to the old methods, I did not even try this till now. I always load through dialogs. I am not a drag and dropper. I've run into issues in the past dragging and dropping files.
Consider this solved.
