Don't think you can but hey, why not ask, I thought...?
If you had some 3D text could you curve in a way that it might be on the outside of a cylinder?
Cheers
Thanks Grant,
As far as I can see 3D Path only changes the position of the characters and doesn't actually bend the text.
I should have explained better, I was looking for text written length ways along a tube so it need to bend around the x axis of the text to match the cylinder.
I had actually tried Deform, but very quickly and so completely forgot to increase (or decrease? 🙂 ) the resolution.
It broke up quite badly so I thought it wasn't designed for text. But changing the resolution to 7 give fantasic results.
Thanks again!
No problem.
Just so that you know for next time, the resolution slider works on a ratio. So having it set to 10 will give you a 10:1 pixel ratio that means it will fill in a pixel every 10 frames. It can be considered as a way to speed up interactivity or decreae processing times if it visually is not an issue.
Setting the resolution to 1 means that the pixel ratio is 1:1 so it will create every single pixel hence better quality and longer processing times.
But I agree that on the surface the slider seems weird to use. But once you know, it should be fine..
Regards
Grant
