Moving from 2013 to 2014 I cant find the file size info in the media hub.
In 2013, legacy import had at the far right, file size, date and time info. Where is this in 2014? I have tried right clicking, looking at list view, metadata fields with no luck.
Solved by ManChicken. Go to Solution.
Not sure if it was missing in 2014, but in 2015 in List view, right-clicking one of the column headings lets me turn on 'File Size'
Thank you. That did the trick.
