Hello Folks!
After conforming an AFF in to my project, I use the cache source media operation to my clips so I can later eject the disk where the original media is. The problem: when I use this operation it says that it's doing it in the backburner localhost, but after I access it to check the process, Its says "waiting" and doesn`t do anything at all! I have done cache source media before and this didn't happend before...
Anyother with the same problem?
I'm using tjhe flame premium 2015
Have a nice day!
We've been having the same problem for 4 months now.
The quickest fix is to open a console, sign in as root. Then type /etc/init.d/stone+wire reload
This will stop and then restart the background servers and then you can go to to your localhost backburner window and restart the captures. This usually makes it run for a while. However, it will continue to stop occasionally, and the process must be repeated. I can't set my system to cache overnight for this reason. Can't seem to get support to fix it. They kept blaming a SAN store server we were using, but we replaced it with a stone, and the problem still exists. Very dissappointed in this system.
