I have discovered this error on two seperate jobs on two different Flame machines (2015ext1 & 2015ext2) which is of great concern. How can Flame lose the setup? Where has it gone? How can I get it back. Do I need to start again? And how can I rely on BFX in the future? This is very frustrating.
happened to me too.
Only once thankfully, but I had to rebuild.
sad to hear it's still there in Ext2.
If I were you, I'd save a snapshot of every BFX, out of habit. I know it kinda defeats the purpose of BFX.... but at least you have a backup.
Thanks Grant! We're defiantely in contact with AD on these new issues - trying to nail down on our side what series of events causes things to break.
The biggest issue for me is, as a former Smoke artist, I've been trying to convert all our Flame artists to do more BFX. Now they're extra suspicious!
Concerning the idea of snapshots...
I took Batch snapshots and saved them with their bumps in the library and found that every bump iteration of a snapshot all had the same problem and wouldn't open.
It seemed to be most of the snapshots that I'd started that day, but not all.
But all the bump iterations for a particular snapshot would either work or not.
Oh man.... ok. Scratch that.
Curious - do you ever start a BFX with handles, and then pull them in, and then give up working on handles and just work with the clip at cut length? Our problems *seem* to stem from when we start messing with BFX handles.
hmmm... how do you mean start a Batch with handles?
I've trimmed out Batch in the Batch Tab and on timeline, and swapped them over, trimmed them in or out and have found it fairly stable.
Used to have problems with Smoke, it used to hate trimming Batch gap effects and would usually crash.
Usually my clips will have 10 frame handles. So I pull up the clip from the timeline, pull out the handles to it's max lenth, and start my BFX in that state. Later, when the heat is on, I might not work on those 10 frames. Just go int BFX and it starts at frame 11.
Gap in Smoke used to get weird that way. Your right.
