mine fails to install. it doesn even start for more than 1 second then it fails.
wierd...
yes I am having the same issue, seems to do something with
Microsoft Visual C++ 2012 Redistributable (x86) Failed
i had to edit the setup.ini to have the installer not to install that
DarrenP
what do yoou have to edit in the setup .ini file?
and is it safe?
thanks!
and is it safe?
thanks!
yes its safe
here is my edited setup.ini for Mudbox 2015
make a backup of yours just rename it and replace it with the one in the .zip file
DarrenP
by default it should be here
C:\Autodesk\Autodesk_MBX_2015_English_French_German_Japanese_Win_64bit_dlm
after replacement try running the install again
assuming this is from the extracted download from the subscription website
DarrenP
Mine installed successfully. The only beef I have is three bugs I wanted fix and their not fixed. There are fixes, I have to try, while others are geared towards those not looking for a little advanced control in Mudbox.
Why Autodesk, Why !
wich tree bugs are you talking about..?
Three bugs which I have a case number for, they were not major bugs or issues, but I would have liked to see them addressed !
could you pm me a short discription of the bugs..?
First I want to say, that there is only one bug, the other two are feature request unless they were not filed as a feature request, want to know what they are as well ? And unless they fixed the bug(s) and renamed it other then the bug number I have one of them is, Increase tolerance for degenerated faces (bug)
