As you can see, the "W" doesn't extrude correctly.
I've tried force 2-sided, subdividing the polygons, experimenting with tesselation settings...I've even swapped font styles but the W always breaks apart.
Anyone have any ideas?
Thanks!
Jason
Solved by BKM. Go to Solution.
Do you try with "ZBuffer-OFF" in node prefs?
Can you increase the scale of your Diffuse map? Is it just not wrapped all the way?
Witch font did you use? I try on my machine...
Once again, Brian to the rescue!
The diffuse map was too small and increasing the scale filled out the text.
Thanks to all for your help!
Jason
