I've been using the Pulldown Tool to add/remove pulldown from clips.
I have textless elements that I need to insert into a master tape and I want to keep the 3:2 sequence.
What's the 'proper' way to do this. At present, I just pick a frame, add puldown, then check it. If it doesn't match, I pick another frame and try again.
How do I use the tool so I get it right the first time.
Thanks in advance.
Frank
