Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
3d Shadow question.
3 REPLIES 3
290 Views, 3 Replies
3d Shadow question.
In action can a 3d text cast a shadow on a Bilinear which has a projection on it? Or do i have to recomp the shadow using actions outputs?
thanks!
3 REPLIES 3
andy__dill
Old projectors may not work--they don't play by most of the rules that other Action nodes do.
New projectors (diffuse maps set to "projection") should work just fine.
thansk Andy, will give it a try. The trick with recomping the output worked but felt bit long winded and cumbersome.. so will try the diffuse.
cheers!
in reply to: andy__dill
Thank you Andy, that worked a treat.
