It's all too easy to create a sketch or body in the wrong component. The reason is that the user has only a small dot to show which is the active component. There needs to be a better way to display which component is active.
The suggestion is to display the Name of the Active Component at the top of the screen, just below the File Name (ie the Assembly Holder).
That way the user can clearly see what the filename (Assembly) is being used and what Component is Active.
It also encourages best practice for beginners to create a New Component, instead of starting with a Sketch and a New Body in the main Assembly hierarchy.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
