I want to use the "One of Three" field validations, but be able to save the record if none of the three fields are filled out.
Currently the "One of Three" field validation prevents the user from saving the record if all 3 fields are empty (and if more than one of three is filled).
Please change this to allow the record to be saved if none of the fields are selected. There is already a "Selection Required" validation so if one of the three fields is required to save, you could use the two validations for this.
OR please create a new validation that is "Either One of Three or None" to allow this validation behavior.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
