Does this permission do anything?
Where do I see the result of someone viewing an item?
I thought I saw it before in the Change Log, but I cannot reproduce this now. Did I imagine this before?
Anyone know how to make this work?
Solved by giliar.defriesperez. Go to Solution.
I have tried on the CUI and on the MUI but there is no line in the Change Log when I look at the item object.
It is strange because the definition of this permission is clear: "Add an entry in the Change Log tab when viewing a Workspace Item"
Hey guys,
Yes, it's supposed to do what's listed in the Help files. Can either of you file a support case for this and let me know? Would like to follow-up internally.
Thank you in advance.
- Giliar
Hi Giliar,
I have the same issue. Shall I raise a separate support case?
Kind regards,
Ross
