- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an issue due to the way PLM handles 'Unit Name' and Unit Abbreviation' from the UOM Manager. The task is to move some BOM's from one workspace to another workspace. When I export a BOM to excel, the column for UOM is in the 'Unit Abbreviation' format. When I go to import this spreadsheet into the new workspace, I get an error on UOM column because I believe PLM is looking for the 'Unit Name' not the 'Unit Abbreviation'. If I edit that column manually, and save the import, the errors go away and I can successfully import the BOM.
In this BOM, all of the UOM's are Each, which was abbreviated as EA. The UOM column from the exported BOM showed all EA's. Once all the EA's were changed to Each's, the import ran successfully.
I believe you should not have to manipulate the spreadsheet or data when performing an export/import. For now I have gone into the UOM Manager and made the 'Unit Name' and 'Unit Abbreviation' the same, which I made EA.
Am I missing something here? Any guidance is appreciated.
