Hi guys,
Is there read access to the aggregated total in a grid? I don't see any access to this value. It also doesn't seem to be available in Reports.
In my case as the linear processes get completed, it will be added to this grid below. At the end I want to take the overall total and post it to the front of the record so I have access to it from a Report.
Here's a similar post which I did not see a response to:
Solved by leungjcp. Go to Solution.
The short term solution that will work for us is to use Reports. In Reports I can extract the aggregate sum. You will need to "enable grouping" and select the aggregate type to show in reports.
In our case we can export the report to excel and find the Monthly, Yearly TAT of our records. This will work for now although it would still be nice to have access to the overall total so I can post that value to the front of the record. Since there ins't access, I would have to loop through all my grid values and total the sum required.
