In Alias it looks like this:
And Fusion makes this lol
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
For this issue, the easiest work around is to sketch out the curve and then use the Patch Extrude command to generate this surfaces.
The results do seem a bit more 3D that I would expect. I'll log this with development to see if this is working as intended.
Before I go, I also wanted to note that if you edit the Tangency Weight field in the loft command for each profile, the results are drastically different.
Thank you for reporting this issues. I will let you know as soon as I learn something.
Claas Kuhnen
Without an isometric view I can't tell what is going on here. Can you post a better view?
here it is:
The loft creates a rather interesting blend surface 😉
the blend surface should not pillow out this way!
Claas Kuhnen
