I get this error from Fusione 360. After click OK or red cross I have same result that Fusion simply exit.
I can't sign out / log in or unflag wor off line.
What I need to do to have Fusion working again?
Thank you.
Solved by f.ciancaleoni. Go to Solution.
Hi
I think you need to reinstall the Fusion 360, because there have been some updates in the last 2 weeks
check this post for unistall
best Rishi
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
I' ve done unistall and reinstall before write first post with no luck.
As I discover the trick was in deleting the options file for fusion 360 in User folder.
In windows 7 the path should be:
C:\Users\USERNAME\AppData\Roaming\Autodesk\Neutron Platform\Options
and the file to delete:
NMachineSpecificOptions.xml
back up it before all.
Now it works well again
Bye
