I am new to CAD, so this may seem like a dumb question to some of you but...
As far as axes are concerned, I have always understood that X is across, Y is away and Z is up (put simply). I did Technical Drawing at school and it was back then.
In Fusion 360, X is red, Y is green and Z is blue. I believe this is a convention as my Mach 3 also uses it.
Can someone explain why, when I draw something in Fusion 360, the blue Z axis is horizontal in the Home window?
When I look at the Front Elevation Red X is horizontal and Green Y is vertical.
I expected to see Blue as vertical...
I am sure that this is the same in other CAD programs and that I have misunderstood something along the way.
Thanks...
Solved by HughesTooling. Go to Solution.
Go to preferences and change the default orientation to Z up, this will not change the orientation of existing designs.
You can change the top view by right clicking the view cube and changing the current orientation to Top.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark, really appreciated.
Makes it so much easier for me to understand.
L
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
