User Parameters - Show quick link to user created parameters
When creating a drawing and using dimension driven parameter I would like to be able to see a quick scroll of the parameter I've previous assigned. If I am working with more then just a few it can get confusing quickly remember exact naming of different dimensions.
Essentially the process would go like
Start sketch
Draw figure
Dimension
Inculded in drop down menu of Dimension would be user parameters (even better create on from that menu as well).
Line or angle dimensioned
7 Comments
I_B_Jones
I agree - though I think the "requirements"/suggestion needs clarifying a bit.
Parameter driven design is very powerful - but currently a bit clunky to use.
Currently (2/1/2016) specifying a (User) Parameter name into a Value field etc. is tedious. I've ended up keeping a separate text pad of the parameter names I've created so that I can easily recall them or copy/paste!!! That's crazy.
What's needed is something MUCH slicker at the data entry point. (i.e. at the Value input field).
E.G. EITHER
  1. Amend the Parameters form (opened from Modify/Change Parameters) so that
  • It can float open like the Browser pane.
  • It does not need to be closed to return to working on the workdesk. Which means valid Parameter changes must immediately be live, not "Applied" by the User.
  • Double clicking on (or some other quick, easy method) a Parameter Name pastes it into the current Value field position if one is the focus. I.e. the Parameters pane becomes a quick lookup/paste method for entering Parameters into Value fields.
OR ELSE
  1. Provide a User Parameter lookup ability from every Value entry field and when entering/amending value expressions. The "Recently Used" is inaddequate.
  2. Add the User Parameters either to the Browser List or to a new List panel and make it possible when entering a Value expression to select a parameter into the expression from the lookup list.
AND (in either case)
  1. Make typing into the Value field pop up a list of relevant Parameters as the typed characters infer, with the ability to select from the suggestion(s) or not.
promm
Thank you for your idea, this is being changed to future consideration.  We have it in our backlog to be able to expose your favorite parameters in the browser as a way to access them in the model.
Mike Prom
Internal Tracking FUS-15813
bverboort
All,
I prefer "
"Provide a User Parameter lookup ability from every Value entry field and when entering/amending value expressions."
From above.
In addition, We need to be able to declare parameters on the fly by entering them directly in the value entry field such as "LENGTH=6"
Best,
Brian
doogin2016
I see this thread is over a year old. Anything new on this subject? It would be nice if parameters menu would stay open while entering
dimensions in drawing mode. Is this possible now? Any help would be nice. Thanks in advance.  Duffy
QuinnCampbell
Only thing that's changed is that there is autofill for user parameters, so as you start to type if something is similar it starts to fill its self, would still like a drop down option too though.
doogin2016
Ya ,I saw the autofill. But I still needed to type the name of parameter before it started to work. I had one parameter named lip and one
name lip height. Until I typed lip height, only lip would show on autofill list. Well one more wish list. Thanks for reply and update.
