Show only
Search instead for
I'm not sure if you imported this trimmed surface from another application or generated it in Fusion. Extend is not going to deliver the same results as untrimming the original NURBS. Either way I investigated and this can be supported. I have created a backlog item FUS-15727.
Ok I am lost in translation here, now for me can you explain what you said in simple English for foreigners
Gah / sorry about that 🙂
I think what's happening is that the way they're mathematically describing surfaces is a bit fragile and breaks down when you do things like extend. The trick is that it's probably not something that they can easily fix without having a way for F360 to know what you're thinking and expecting to happen because to the program it's all just numbers.
That said - finding ways to make Fusion do more intuitive and sensible things would be great.
