Reverse - Mirror Text Button
A flip button to reverse - or Mirror the Text from normals when enbossing or de bossing text into a model.
I have come across this problem when embosing text into a part.
I had to turn the text into a seperate body then position it to then subtract from the model body to enable the text the way i wanted it.
6 Comments
anewenergy
 The sketch text command does not allow for reversing.  When we engrave in mold cavities, we need to be able to flip the engraving around so when it comes out of the mold, it is read from left to right.  Currently the software tools allow you to rotate, but not mirror.
keqingsong
Status changed to: Gathering Support
brianrepp
Merged with another similar idea from Pat
I would also really like this to happen. There is extensive workarounds but I keep thinking it should be a simple command.
WBAutoDesk
Yes oh yes please. Ability to simply flip text so one can emboss or extrude would be so much faster than creating a separate body, then having to merge/join/cut and realign, etc.
rohit.bapat
Fusion 360 now supports Text Flip functionality. Please check latest production build.
Thank you,
Best Regards
Rohit Bapat
