Suggestion: refine of the UI of selecting 1..3 elements
The problems with Align & Snap (discussed elsewhere) refer to working points and planes a lot. These are under the Construction toolbar menu and today I tried them out.
The UI for selecting elements (points, edges etc.) isn't completely obvious, and it's not coherent either.
Let's take the coherency issue first.
Select Construct > Offset Plane
This needs just one element, a plane and communicates it clearly:
( What could be done here is to use color coding on the arrow icon like I think Inventor does. White background: not selected yet. Blue background: selected. Here it seems to always be blue which lead me to think I had a plane selected. Anyways - check Inventor and do alike. )
Now, take i.e. Construct > Plane Through Three Points
That's ALL you get on the screen.
And if you click the 'option' icon, you'll see this:
Seems like only one point (or something) is needed, but it's actually all three. (For the first, this means the first point, then the second point, then the third… but since there is no visual indication that some points already got selected, the user is confused - unless she/he knows the drill.)
Granted, if you do NOT do anything, this tooltip will surface:
However (based on your personality) you might never see it. I hadn't. My way was to click all possible, not to wait for a tooltip to surface.
A better way would be alongside how 'Offset Plane' selection works (and how Inventor works, I think):
This makes the tooltip unnecessary and allows changing selections of the 1st and 2nd elements, if needed (current workflow doesn't, which is part of its problem - it also only gives feedback on successful selections by changing the color of the selected elements; this method is *already* used in Fusion and should imho be the *only* method used. Or vice versa - experienced users may choose only to have the "driving blind" option since they know what they're doing. That's fine. But behavior with Construct > Offset Plane and this should always be coherent.)
(btw this is on Fusion 360 v.1.8.568)
(I'll make the selection order into another message, though these are kind of related.)
1 Comment
keqingsong
Status changed to: RUG-jp審査通過
