One of the most annoying parts of the engineering aspect of Fusion is that when I change dimensions of a sketch in Fusion the sketch moves.
Here is an example: So I change the radius of the fillet and instead of the top getting
smaller or bigger (change of radius) also the triangle changes it's size.
The point of constraint sketches is that I can place them where needed and extrude
my solids out of them and when adjusting the sketch the solid will be adjusted.
As a designer I do not want to reposition my solid after editing the sketch!
