Hi There,
Can we please have the ability to rename joint origin instances.
When inserting parts into a design, and using the browser to select joints, if I have multiple joints for various important embedding / connection points, then I cannot tell which is which from the browser.
So for example if I had joint origins I had renamed to "surface flush" and "On surface" then my assemble joint workflow via the browser heirachy would be far easier.
Thanks.
