Place multiple holes at once on sketch points.
Sketch based hole pattern or in other words the ability to locate multiple identical holes on sketch points or references with the hole menu open.
Screencast
7 Comments
TrippyLighting
 Somehow the sound is missing in the last section of the sreencast. The sentence that I started" it would be even better..." was cut off.
What would be even better if at that stage you could already select the part of the hole that is to receive the tread, so you would not have go through a click orgy after creating the pattern.
schneik-adsk
Status changed to: オートデスク審査落選
This will be in our next update.
TrippyLighting
Now THAT is awesome! Thanks!
schneik-adsk
We are happy to report that this was made available in Jan 2014 update.
TrippyLighting
Very Nice. Here's a ltiite; screencast of how it works:
https://screencast.autodesk.com/Main/Details/f215f198-e667-4129-b107-5d351603567a
Notice that the "OK" button never highlights. The "Enter" key, however, completes the commnad.
rada.mar
 great implementation! it's been a while that I've been thinking about this I had so much work before designing with many holes..
jsargentina7
Does anyone know if the multilple holes will be perpendicular to the surface it is cutting into? For example, if I want to have a bunch of holes that are evenly spaced on a complex curved surface, could I just select the points on that surface and all the holes will follow that surface or will they cut the same direction as the first hole?
