Show only
Search instead for
Somehow the sound is missing in the last section of the sreencast. The sentence that I started" it would be even better..." was cut off.
What would be even better if at that stage you could already select the part of the hole that is to receive the tread, so you would not have go through a click orgy after creating the pattern.
Does anyone know if the multilple holes will be perpendicular to the surface it is cutting into? For example, if I want to have a bunch of holes that are evenly spaced on a complex curved surface, could I just select the points on that surface and all the holes will follow that surface or will they cut the same direction as the first hole?
