On a MacBook track pad, the new F360 has a weird default behavior where two fingers will very often pivot the camera. It's not a bad thing but that should have a bit more elasticity to it because as it is it’s far too easy to pivot (or it should be disabled by default if you can’t make it work reasonably).
Also pinch to zoom should be supported and enabled by default.
