Show only
Search instead for
Provide an ability to place multiple identical holes at a time. Would be great to snap them to a sketch, or snap to other features on a body. Actually, it would be truly awesome to snap coincident to bodies other than the active body.
Yes, great suggestions.
When you first the hole command you can pick a single sketch point to place it.
When you have the position manipulator active you can select edges of other features (on the same body) to locate the hole.
But the points you make are great suggestions and we definitely can make this A LOT easier.
Cool, thanks for the tips. My most common use case is when I have clearance or tapped holes on one body, and I want to align matching clearance or tapped holes in another.
this will be a great feature, speacilly when you make a pattern and want to make holes on the vertices.
Now, you always need to reclick on the hole function, and reedit the diameter and depth, is too much repetive work for something that can be easy implemented.
Thanks for the input. An update: we've started work on the ability to place multiple holes on sketch points. This is being tracked internally as FUS-5737. I'm hopefult that this will be available shortly after the first of the year.
