Move Command in timeline needs to remember translation values
For move and rotate if possible also scale
Otherwise that feature is pretty pointless and dumb - dumb because it only functions as a marker but when editing the feature
does not tell you how far you have rotated or moved so you as a user can guess what you did 3 weeks ago.
The fact is the features remember that because in the timeline when you move forward and back the values selected
are applied by the feature. so why not expose that inside the UI instead of giving the user always empy value fields?!
Makes sense doesnt it?!
if I rotate an object I do not want to be forced to later measure the degree I rotated with.
so when I entere the rotation value
I think the feature should remember this and next time I edit it should still show it
Blender Rhino or Alias can do it!
7 Comments
brianrepp
Status changed to: Gathering Support
colin.smith
This is currently in our backlog, release TBD.
jakefowler
@cekuhnen/All -
We're looking into this improvement now, as part of wider improvements to the Move and Align commands. There are a few alternative approaches we can take for recording Move history; if anyone has answers/thoughts on the questions below, that'd be extremely helpful feedback:
1. Say we recorded object movements as a series of sequential 'steps' (we're thinking these could be presented as a table). Would you consider each drag/value change as 1 discrete editable step? Or would you prefer sequential moves to be grouped together? (e.g. if you moved in Y by 10mm, then X by 20mm, should this be represented as two seperately editable steps, or a single "X: 20mm, Y: 10mm" step)
2. If you perform a point-to-point move, would you expect the timeline feature to just store + allow editing of the XYZ transform values? Or actually remember the two selected points in an adaptive manner? (i.e. so that if one of the bodies were modified 'before' the Move in the timeline, the Move would adapt to that change)
3. Something we've also discussed as part of this is merging Move and Align into a single command. If we were to do this, question 2 applies to Align as well; should the timeline feature remember the transform values, or remember the picked geometry? (also very welcome are thoughts on whether combining the Move + Align commands would be sensible/useful)
Thanks in advance!
Jake
jakefowler
Status changed to: オートデスク審査落選
Hi all,
This is well in development now - the plan is to release this functionality in January 🙂
The improvements necessitated some changes to the design of the Move command. It would be great to get some early feedback on this - if anyone is interested & available to take a look at what we're working on, please drop me a PM!
Jake
cekuhnen
@jakefowler
Ah man that is great news! Count me in to take a look at it.
Adding a better move command really brings Alias Blender Maya Rhino like object positioning skills to Fusion 360 and that is great to have when paired with sketch driven geometry which are not so easy translated.
fredgenius
Simple. If I rotate an object by 59° about X, then later want to reference that value so I can rotate other objects to match, I should be able to edit the original move feature and see what that value was. It would be VERY useful, if the original pivot point was retained!
I also note, the move values are not in the Parameters list, where it would be easy to reference, and modify.
xrok11
"recorded object movements as a series of sequential 'steps' (we're thinking these could be presented as a table). "
This is a good idea and the point to point could be included in the list
