Mirror and pattern components
Mirroring and creating patterns out of components should be as easy as it is with bodies. Including the ability to keep of break the linking between those components. ( If the component is linked to a separate file , the link should break )
9 Comments
brianrepp
Status changed to: Gathering Support
Waiting for this feature to be implemented. It would be really helpful to avoid the workaround of mirroring the bodies and converting them into components.
Tags (2)
daniel_lyall
you can do it inside a component then you don't need to create a new component
keqingsong
colin.smith
Status changed to: オートデスク審査落選
Component pattering is in the product today.
Mirroring of components will be in an upcoming release, it is being worked on now.  Aiming for March.
keqingsong
Mirror Component will be available in the May 7 update.
keqingsong
KirillChepizhko
Fantastic!
Hell yes!
