Make it easier (possible?) to delete and rename files/folders within Fusion
I created a project folder and I do not see an obvious way to delete it or even rename it without going into A360 in order to do so.
Seems like there are a lot of improvement that could be added to the Fusion 360 Data Panel such as making this easier and accessing different versions we have saved as well.
10 Comments
BrienKing
I was just about to make this suggestion, glad I'm not alone.
There are also projects you cannot delete that I don't need such as the "Demo Project"
We should be able to move things around, rename, delete, etc...
CapGuy
YES !
nota bene : as this seemed to be obvious for me, I have already done this request/suggestion within the "feedback" link in the help menu of Fusion, but never received any answer, so I thought nobody take care about any 'feedback' sent...
charegb
Status changed to: オートデスク審査落選
We are adding the ability to copy/paste/rename folders in the next update (currently scheduled for the end of this week) and the ability to rename projects right inside fusion in the July update.
You will still not be able to delete the demo project but we will work on that next.
Bankim
charegb
Hi Capguy,
We do read each email that comes in to the feedback email. We try to reply to all of them too but we could have missed responding to yours. Apologies for that oversight.
Forums and idea station are a beter way to process the feedback because the community can see it and build on it too!
Cheers,
Bankim
CapGuy
Hi Bankim,
Thank you very much for these apologies, I did not need it, but you show how much you are very concerned by you work, so it is a real pleasure to work with you !
Good news for these 'folder and project abilities' within the data panel directly in F360, thanks also for this.
Best Regards,
Guy
charegb
Implemented in the July update.
CapGuy
Hi all,
Just after some check I see this old topic... So because there is nothing to "thumb up" I would like to thanks (a lot) the team to be there, to listen us, to help us improving our skills using their software, well, to thank you so much for this becoming always more and more wonderful tool !
Best Regards,
Guy
knndnnr
How about the 'Projects' folder as well? Great to have "Delete' within a project, but still only have 'Rename' and 'Archive' in Projects.
charegb
Hi @knndnnr, Once you archive a project, you can go to the archive tab to delete it.
The 2 step delete is a safety feature for accidental deletes.
Bankim
knndnnr
Thanks for informing me of what should have been obvious. I need to think
more first.
