Keep constraints dialogue box open while I sketch
I'd like to have the ability to keep the constraints dialogue box open while I'm sketching. It's great that I can keep it open and apply multiple constraints one after the other, but often I find I need to add some sketch features, and then I have to go click on back to the constraints. Jeez y'all, that's like two clicks and a hover. 😉
9 Comments
cekuhnen
a constraint toolbar or pull down might be great!
michaelpgeyer
Great suggestion David, seems like it would be a great addition.
I was goint to submit this myself as it drives me nuts having to keep opeing the dialog.
MichaelAubry
Hey David,
We're set to do a new round of sketching optimization for the next release. Great suggestion.
haughec
Great suggestion.  Good new - we're working on this now!  The constraint command will soon be replaced by a persistent "Sketch Palette" which will be presented whenever a sketch is active and will allow you to apply sketch constraints at any time without the need to invoke a separate command.  The palette will also include sketch-specific toggles, like grid snapping on/off and the ability to slice the model at the sketch plane to better view your sketch.  I'm hopeful that this will be available just after the first of the year.
Thank you,
Charles
haughec
Status changed to: オートデスク審査落選
Big Thanks!
yoshimitsuspeed
Also ctrl Z should undo the last action, not close the box or exit out of that function before undoing.
JamieGilchrist
