Hold shift to constrain horizontal/vertical dragging of sketch element
I'd like to be able to hold SHIFT whild dragging a sketch elelement to contrain the dragging motion. Not to be confuse with adding a horizontal/vertical constraint.
J.
3 Comments
That can pose a conflict with the navigation!
schneik-adsk
Status changed to: オートデスク今後検討
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this idea is getting archived due to the nature in which we use modifier keys.  Holding shift already is used to rotate a model and since there are users that like to sketch in 3D removing this ability to add the function in your idea would cause confusion.
Mike Prom
