Export STEP in mm
Export STEP in mm
Correct me if I am wrong, but it appears that the STEP file export is in centimeters, which is a little confusing for those using the file. Could we have an option to export the STEP files in millimeters?
5 Comments
HughesTooling
The best bet would be for the stp file to have the same units you are working in.
Mark
brianrepp
Status changed to: Gathering Support
colin.smith
Status changed to: RUG-jp審査通過
Archived due to lack of votes.
Is the export in cm considered a feature?
It quite confusing when importing model in other systems. In particular, working with some analisys software that uses no units gets really tricky. Exporting in the units one is working on would be perfect. Can this be reopened?
Hi please add the option to export stp file in to mm please. Normally this should be standard in mechanical drawing, not cm.
Thanks a lot in advance!
