Curvature graph along surfaces not just edges
this is quite an important tool to make sure how your surfaces flow not only along their boundary edges.
3 Comments
deyop
Status changed to: オートデスク審査落選
This would be a useful analysis capability and likely would work with a cross-section command where multiple sections could be defined.
cekuhnen
it is really a must have, you do not want a designer to split faces or worse project curves onto the surfaces so they can read out the curvature after making the surface!
promm
When converting a T-Spline you can select edges to keep and those edges can be used to do a curvature comb analysis.
Mike Prom
