Copy and Paste objects between designs
Objects (DM) and sketches should really be able to be copied between designs.
The export and re-import function is a labor intensive work-around.
3 Comments
How do you do the workaround?
schneik-adsk
Status changed to: オートデスク今後検討
promm
Class,
Thank you for your idea, we have a workflow as a part of distributed design plan that will solve your issue.  When work is started the idea will be changed to accepted.
Mike Prom
