control file versions inside Fusion and not webinterface
now fusion file versioning is pretty nice
that I have to go into the web interface to adjust that is ok but I should be able to do that also via Fusion itself
otherwise it is a lot of Fusion web to fusion to web etc ...
http://forums.autodesk.com/t5/post-your-tips-and-tutorials/how-to-roll-back-your-design-to-an-older-...
4 Comments
charegb
Status changed to: オートデスク審査落選
Hi Claas,
THis is somethign we have been disucssing internally too because it has come up in user research and it will be in a future update.
Bankim
charegb
We are trying to solve 2 sets of problems here. We will solve the first bullet point below in the Feb update and the second bullet point in the update after Feb.
  • People need to open older versions to copy or externalize some components in that design. We will support this by allowing you to open any older version of a design in read only mode.
  • People need to promote an older version of a design to go back to a point in the design and evolve it in a new direction.
cekuhnen
Great thanks for the update!
schneik-adsk
