Coil improement
Coil improement
Coil really needs an option to have the profile perpendicular with the helix not parallel with the axis. It looks OK if you have a fine pitch.
But if you have a course pitch the cross section becomes deformed.
Mark.
7 Comments
Oh wow yeah that's awful
Also - how could 6 other people look at this, yet I'm still the first to upvote it ?!?
It's not like we have a finite number of votes, and it'd be hard to find a more obvious «no-brainer»
HughesTooling
perhaps it's because I can't spell improvement!
[retracts vote]
kb9ydn
That is exactly what it needs.  The profile needs to be normal to the helix.  Though I wonder if a sweep might be better for this.
C|
Yes, that definitely needs to be fixed.
If you get stuck because of this, a workaround is to get the size and pitch to where you want, then set the section position to inside. Make a sketch, 3D Include the outside seam line of the coil. In the browser remove the body of the coil. Use the pipe command to recreate the coil using the 3D sketch. Now the profile will run normal to the curve..
But yea, that should obviously be an option (the default even) in the coil command to begin with.
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived.  We have plans to create a helix sketch and expand the sweep tool to control pitch.  These improvements will solve the issue that you bring up, we feel that the coil command is not the correct place for this functionality.
Cheers,
Mike Prom
