I've only now just begun playing with Fusion 360 and one thing I've noticed is the fly-out menus in 2d and 3d cam. Is there anyway for them to be static, or moveable and pinned to the side of the scree? Doing extensive programming, it will get old having to click, click and then go.
You can add buttons from the flyout to the toolbar.
In a fly out, at the right end of the menu, there is an arrow that will pop the command onto the toolbar.
Riiiiiight. And then I end up with a very long very large bar that I can't resize or even have go vertical instead of a constan horizontal. How about making them small seperate enitities that, oh, I don't know, move to the far left or righ on their own bar set?t. Maybe even putting some intelligence into them, so when one goes into CAM mode (or even modeling mode), your entire bar layout is changed and it's totally customisable to ones taste (within reason).
There is that entire blank space above the very large toolbar that is basically wasted space. Granted, some of that will get taken up with project names, but there is still 10-16 inches of wasted space in that are (depending on monitor of course)
Just a thought........
