Calculator in measure tool
Many times i switch between MAC calculator and use the number i get from the measure tool.
Can Fusion have a calculator in the mesure tool instead.
6 Comments
kb9ydn
That is a really great idea!  I would also request that there be a setting for it to operate in reverse polish notation.
C|
maruska
If you can type equations in data entry fields, in what situation would you use this? I usually just do all my math when I'm entering dimensional values (i.e. (25.7mm+4.2")/2  ).
kb9ydn
You would use this in any situation where you aren't entering dimensions; like when you're just thinking about possible options for a design.  I also tend to fabricate simple parts directly off of the model on the screen (instead of making 2D drawings), so it's really handy to be able to take measurements and do simple calculations.
C|
maruska
Cool - thanks. I was just curious what your particular use would be.
schneik-adsk
Status changed to: Gathering Support
schneik-adsk
Status changed to: オートデスク審査落選
