It would be incredibly efficient if the Dialogs would have an APPLY button. As an example, if I need to move objects, I need to go into the MOVE dialog and then, move the object and hit OK. If I have many more to move, I have go into REPEAT MOVE. If I had APPLY, I could apply the MOVE, leave the Dialog open and continue to move my objects and just APPLY. There are many other tasks that this option would be of help as well.
UNDO option: if I go into EDIT FORM, set my options and then make the edit via the manipulators - if I make a mistake, my only option is to cancel everything. The UNDO ARROW also cancels my entire setup. If there was an UNDO button on the Dialog, I could keep my setup and only undo my edit via the manipulators.
There functions may already be there, but I'm not aware of the,
. Thanks, David Gall
