Show only
Search instead for
The ability to export to STL is very important to me and it does not appear that it can be done in Fusion 360. It can be done in the old Inventor Fusion. Pleas add this feature....
Ok... I found how to export to STL but the files are not readable in my slicing program. I am having to export to STEP then open it in Inventor Fusion then export to STL to get it to work...
I'm surprised you're having trouble. I've sliced with KISSlicer and Slic3r, and loaded all my exports in NetFabb and haven't had any errors. What are you using to slice? At the least it may be better workflow to export the stl, load it in NetFabb, and export STL from there.
