Freewheel (Read Only)
Wish: Sharenow AutoCAD sheet set .dst
2 REPLIES 2
385 Views, 2 Replies
I like the idea to select a DSD file in AutoCAD. But think it would be even more useful to be able to select an AutoCAD sheet set file (.dst). Then print based on the sheet set dst. (I personally hardly ever save dsd files, since its soo easy to print using page setup overrides). So being able to select a .dst and print the sheet set to DWF would be great!!
Mark Douglas
2 REPLIES 2
I will record this wish.
wrote in message news:5681601@discussion.autodesk.com...
Mark Douglas
While we don't have that exact feature, there is an easy workaround you can use. When you are in the Sheet Set Manager, there is an option on the drop down menu to convert your DST data to a DSD file that can be used with ShareNow.
See the attached screen shot.
The steps are:
1) Select the desired sheets in the Sheet Set Manager. You can select the root node to use all sheets, or use CTRL-Click to multi-select specific sheets.
2) In the Sheet Set Manager toolbar, click the drop-down arrow next to the middle toolbar icon.
3) Select the "Publish Dialog Box..." option. This will take your selected DST sheets and create an unsaved DSD file and open the Publish dialog box with that DSD data.
4) In the publish dialog box, save the list of sheets to a DSD file.
5) Use ShareNow to publish your DSD to Freewheel.
