I am trying to pass a variable to the Freewheel iframe in order to select the section displayed in a dwfx file with multiple sections.
I have created a .php file with navigation links as follows:
<ul>
<li><a href="3D_DEV.php?selection=1">section a</a></li>
<li><a href="3D_DEV.php?selection=2">section b</a></li>
<li><a href="3D_DEV.php?selection=3">section c</a></li>
<li><a href="3D_DEV.php?selection=4">section d</a></li>
</ul>
I set the variable 'selection' as follows:
<?php
$selection = $GET['selection'];
echo $selection;
The iframe looks like this:
<iframe scrolling="No" width="600" height="400" src="http://freewheel.autodesk.com/dwf.aspx?path=http://www.mywebsite.com/CAD/16PS.dwfx&sec=<%selection%>"> </iframe>
When I include this variable in the iframe it seems to ignore the path and displays the default image, but when I replace the variable with a number it works fine. The echo command shows that the variable is being set properly. What am I doing wrong? Can you offer a better way to do this?
Keith
