Freewheel (Read Only)
Using viables in the iframe
1 REPLY 1
tilehaus
876 Views, 1 Reply
I am trying to pass a variable to the Freewheel iframe in order to select the section displayed in a dwfx file with multiple sections.
I have created a .php file with navigation links as follows:
<ul>
<li><a href="3D_DEV.php?selection=1">section a</a></li>
<li><a href="3D_DEV.php?selection=2">section b</a></li>
<li><a href="3D_DEV.php?selection=3">section c</a></li>
<li><a href="3D_DEV.php?selection=4">section d</a></li>
</ul>
I set the variable 'selection' as follows:
<?php
$selection = $GET['selection'];
echo $selection;
The iframe looks like this:
<iframe scrolling="No" width="600" height="400" src="http://freewheel.autodesk.com/dwf.aspx?path=http://www.mywebsite.com/CAD/16PS.dwfx&sec=<%selection%>"> </iframe>
When I include this variable in the iframe it seems to ignore the path and displays the default image, but when I replace the variable with a number it works fine. The echo command shows that the variable is being set properly. What am I doing wrong? Can you offer a better way to do this?
Keith
1 REPLY 1
scott.sheppard
in reply to: tilehaus
I checked with one of our developers, John Schmier, and he told me that unfortunately we do not support this. This is something that we can consider in a future update.
Scott Sheppard
Program Manager
Autodesk Labs
