Freewheel
New Member
0 Kudos
Post 1 of 3
?path=https://... not working.
1602 Views, 2 Replies
04-14-2011 01:18 PM
Hi, I am trying to use Freewheel on our site, and our site runs over SSL. Therefore the URL I pass via the path= parameter is https://. When I do this, I get the following error:
The requested DWF is not valid.
If I use http:// it works just fine. Also, I can see from my HTTP server log that I am in fact sending the file over HTTP or HTTPS, so the only difference would be the server certificate validation that is happening within your software.
I imagine this must be because our certificate is not valid as far as your HTTPS client is concerned. The UserAgent shows WinHttp.WinHttpRequest.5, which I assume is a Microsoft HTTP component you are using. Are you by chance missing the GlobalSign root certificate on your servers?
http://www.globalsign.com/support/rootinstall.html
Thank you for your consideration.
New Member
0 Kudos
Post 2 of 3
Re: ?path=https://... not working.
04-14-2011 04:46 PM in reply to: btimby
I tried a different https:// site with a certificate from GoDaddy and it worked fine.
I am fairly certain now that it is this specific certificate (more accurately, the CA).
Thanks.
Board Manager
26 Kudos
Post 3 of 3
05-02-2011 05:57 PM in reply to: btimby
Thanks for the detective work.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
