Freewheel (Read Only)
?path=https://... not working.
2 REPLIES 2
1917 Views, 2 Replies
Hi, I am trying to use Freewheel on our site, and our site runs over SSL. Therefore the URL I pass via the path= parameter is https://. When I do this, I get the following error:
The requested DWF is not valid.
If I use http:// it works just fine. Also, I can see from my HTTP server log that I am in fact sending the file over HTTP or HTTPS, so the only difference would be the server certificate validation that is happening within your software.
I imagine this must be because our certificate is not valid as far as your HTTPS client is concerned. The UserAgent shows WinHttp.WinHttpRequest.5, which I assume is a Microsoft HTTP component you are using. Are you by chance missing the GlobalSign root certificate on your servers?
http://www.globalsign.com/support/rootinstall.html
Thank you for your consideration.
2 REPLIES 2
I tried a different https:// site with a certificate from GoDaddy and it worked fine.
I am fairly certain now that it is this specific certificate (more accurately, the CA).
Thanks.
scott.sheppard
Thanks for the detective work.
Scott Sheppard
Program Manager
Autodesk Labs
