Freewheel (Read Only)
How to map xml file of DWF file in java
1 REPLY 1
alisha5
2938 Views, 1 Reply
I have an DWF file i will zip that file and then after extracting i get .xml file and this file contains information of that image parts then how i map this xml file in java.
1 REPLY 1
scott.sheppard
in reply to: alisha5
A DWF file is a zip file; however much of the 2D and 3D content in it is binary. Unless you are programming in C++ with the DWF Toolkit (which is free and downloadable from Autodesk), you will want to use Design REview or Freewheel to handle your DWF files. The alternative is DWFx which is really an XML Paper SPecification (XPS) document.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
