Freewheel (Read Only)
freewheel server changed
2 REPLIES 2
394 Views, 2 Replies
Today I noticed that my viewer stopped working. It turns out the requests from the freewheel server to my webserver are now coming from a different IP address. It used to be 64.95.221.15 and is now 64.95.221.27. In order to limit access to the dwf files I had previously restricted access to the old IP address. Is there an announcement list for these types of changes or is there a way to protect against this in the future without allowing total public access to the dwf files?
P.S. I realize that anyone can view my dwf files by making their own requests to the freewheel server, but at least they cannot access the dwf files themselves if I restrict access as noted above.
Mark
2 REPLIES 2
It sounds like you are relying on Freewheel for production work. For this
you want Autodesk Freewheel instead of Project Freewheel. The IP addresses
of http://freewheel.autodesk.com is 72.246.216.73. I have the Project
Freewheel IP as 69.26.52.96 so I am not sure about the numbers you have
here. To use Autodesk Freewheel, you would change dwfit.com references to
freewheel.autodesk.com. Everything else should be the same.
wrote in message news:5635795@discussion.autodesk.com...
Mark
Thanks for your reply. I wasn't really aware of the distinction between the two sites, but I confirmed that I am using "freewheel.autodesk.com". Does this discussion group apply to both?
So the server change apparently happened at "freewheel.autodesk.com". The ip addresses I noted are the ones that appear in my webserver logs when I request an image from autodesk, so maybe the request gets handed off to a server pool or something. Maybe I need to permit access from a range of addresses, but I don't know how to determine what range that would be.
Mark
