Freewheel (Read Only)
Configuration out of Freewheel
3 REPLIES 3
315 Views, 3 Replies
I want to know, are there any possibilities to built up a configuration Tool with Freewheel?
I want an online tool for customers, which creats different variants of the same part, only with different memebers. Like iparts or iassemlbies in Inventor.
Any ideas, or do you know other possibilities how i can creat online configruations?
Best, Alex
3 REPLIES 3
Check out this dynamic street lamp assembly from Holophane:
http://192.234.68.95/CC_host/pages/custom/templates/HLP/assemble.cfm?cc_nvl=()&cc_tsf=&cc_tvl=()
You pick your parts. They use Inventor to assemble a lamp. They publish a
DWF. Right now it shows you the DWF using Autodesk Design Review; however,
the HTML tags they use could be replaced by
Hello Scott,
Thanks for your response. OK, but that sounds like a lot of work.
Is it possible to publish a single DWF to slide through iPart-Members? Like changing a member of an iPart-family in Inventor? That would be great. So I can create an single DWF and see different members of an iPart-mother. I know, I can create a multi DWF-sheet. But that is not what i want. I want a reference to a single document.
Can you help me?
Best, Alex
You want users to see different sets of 3D geometry based on their choices.
Depending on how many choices they can make, there is probably no way you
could prepare that many different 3D models - even if they were in the same
DWF file (which they could be). Based on my experience, publishing blocks of
3D data and then merging them is a more difficult task than configuring an
authoring tool to publish the correct result for you. The publishing tool,
such as Inventor, does the culling and merging for you. DWF is a published
format used for data exchange.
wrote in message news:5838189@discussion.autodesk.com...
Hello Scott,
Can you help me?
Best, Alex
