I cannot find my Formit-files in Autodesk 360 on web - why is that?
I did find it 5 days ago - but when I am now looking for it, I only find my projects. I cannot find the folder called "Formit"
How and why should we rely on Autodesk ID, Autodesk 360 cloud and such - when we cannot easily access several-hours-worked-on model files?
Please help!
Solved by cblocher. Go to Solution.
Solved by racel. Go to Solution.
Hi kommune81-
Which 360 site are you logging into? 360 Drive (https://360.autodesk.com/) or 360 Projects (http://autodesk360.com/)?
Currently, FormIt files are saved to 360 Drive. You will need to visit https://360.autodesk.com/ to access 360 Drive files. The "FormIt" folder will be there. Sorry for the confusion. We plan on working on resolving this issue as more users begin working on 360 Projects.
-Racel
Hi kommune81-,
If you're signed into your A360 hub and you have an A360 Drive account with folders and files, you can access them.
You should then be able to see the Formit folder from A360 Drive in your A360 hub.
Best,
Chris
Thanks!
It was unclear before - but now its clear 🙂
I also want to thank you for the hangout-session/webinar about A360 and A360 Drive here:
https://www.youtube.com/watch?v=xZEdAx-RJ3M
Harald
